mari720413@gmail.com Posted April 20, 2020 Report Share Posted April 20, 2020 Hello, In a project i have controller model USP-104-B10 connected to Energy meter via Modbus RTU. More of the variables are UINT32. It is simple read UINT32 then swap ABCD_CDAB to get value. Which is the simplest way to read UINT64. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted April 20, 2020 Report Share Posted April 20, 2020 Please follow Help Center Article "UINT64 As String" https://support.unitronics.com/index.php?/selfhelp/view-article/uint64-as-string Hope this is what you need. Quote Link to comment Share on other sites More sharing options...
