Sign in to follow this
Charlesc
UAC and Data table
HI!
I would like to know if i can use UAC on my data table, i explain.
I use two level access, and i want the first, can only read and chose a row in my table, the second can be use the button "edit on" to modify the table.
It's possible to put a level access on this button?
As far as I know, it is only possible to make data table visible / invisible based on access level.
I would use two different data tables overlapping with visibility restrictions and Read-only box checked / unchecked
