IgorM Posted April 29, 2020 Report Share Posted April 29, 2020 Dear support team, Is there any possibility to export ladder project from u90 and then import it in the visilogic sw? Thank you! BR Igor Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 29, 2020 MVP 2023 Report Share Posted April 29, 2020 No. The ladder logic between the U90 and the Vision series is similar, but the HMI is totally different. You have to re-design how the screens work and flow on the Vision. When I've moved a U90 application to a Vision I just sucked it up and had both applications open on two monitors, re-entering the logic from the U90 manually into Visilogic and then making new displays. Joe T. Quote Link to comment Share on other sites More sharing options...
