alechko Posted April 30, 2020 Report Share Posted April 30, 2020 HI, I NEED HELP. I HAVE V130 MI0= 40001 ML0=? THANKS Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted May 1, 2020 MVP 2023 Report Share Posted May 1, 2020 If you look in the Help under the Modbus functions, you will eventually find the Slave Address tables. Here is the one for registers- ML 0 = 7000h, which translates to Modbus register 428672 + 1 = 428673. Hopefully you can handle six digit Modbus register numbers. Joe T. Quote Link to comment Share on other sites More sharing options...
