Dainius Vaskela Posted May 1, 2020 Report Share Posted May 1, 2020 Hi, I have problem with unistream PLC. "CPU Startup Error" see in attached picture. And also I can't connect to PLC via USB. Maybe someone have idea how to fix it Quote Link to comment Share on other sites More sharing options...
NoamM Posted August 27, 2020 Report Share Posted August 27, 2020 Dear Dainius Vaskela, You have a problem on PLC start-up that will likely resolve if you "Download All" the project from UniLogic to the PLC. If the problem continue open a ticket on Unitronics "Help center" at https://support.unitronics.com/index.php the Support team will assist. Quote Link to comment Share on other sites More sharing options...
