TheDave2 Posted June 30, 2011 Report Share Posted June 30, 2011 Where is the information for the UniCan Send block ? Searching the HELP files reveal nothing. Is VisiLogix ever going to get context sensitive help ? I.E., when the block is selected, pressing ALT-F1 should bring up help about that instruction. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted July 1, 2011 MVP 2014 Report Share Posted July 1, 2011 Here 'tis. Quote Link to comment Share on other sites More sharing options...
TheDave2 Posted July 1, 2011 Author Report Share Posted July 1, 2011 Thanks ! Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted July 3, 2011 Report Share Posted July 3, 2011 Hi Dave, I'm Cara, your friendly neighborhood technical writer I give context-sensitive Help where I can. VisiLogic was one of the very first Windows-based PLC-HMI programming packages. Unfortunately, that means that it has some limitations. Some of our dialog boxes, for example, COM Init, are designed so that I can add a Help button; and if you are actively editing COM Init, pressing F1 will open the Help file to that topic. However, the UniCAN Send function uses what our developers call a 'generic form'. I cannot add context-sensitive Help to these. In cases where there many requests, sometimes the developers will re-engineer a function to allow it. That said--if you look for information and don't find it, please do contact me, either via the forum or support@unitronics.com. Sometimes, the information exists but I haven't anticipated how a user might look for it. In such cases, it takes me a few minutes to add Search terms, or create hyperlinks. If the information doesn't exist...I have work to do. Simon, who originally answered your query, has given me a lot of work over the years. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted July 4, 2011 MVP 2014 Report Share Posted July 4, 2011 Hi Cara Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted July 4, 2011 Report Share Posted July 4, 2011 Simon! Cobber, I'm pleased to see you haven't fallen of the bottom of the earth, over there in upside-down Oz:P Quote Link to comment Share on other sites More sharing options...
