phu.vu@ptt.vn Posted May 18, 2020 Report Share Posted May 18, 2020 Hi I have a HMI PLC V350, I want to upload program but it didn't not allow and display warning "This project cannot be uploaded because: - the option 'Burn Upload Project' was not selected when the project was downloaded, or - due to incomplete data in the PLC" Please help me solve this! I have already been purchase new one to replace the damaged HMI PLC. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted May 18, 2020 Report Share Posted May 18, 2020 It is not possible. You must contact the programmer to get a copy. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 18, 2020 MVP 2023 Report Share Posted May 18, 2020 The other option is to save the program to a file on the SD card, but once again, this is an option the programmer must authorize in the original program (and supply you with a password). This is intentional to protect the intellectual property of the programmer. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted May 18, 2020 MVP 2023 Report Share Posted May 18, 2020 10 hours ago, phu.vu@ptt.vn said: .....replace the damaged HMI PLC. If screen damaged or touch sensor and program transfer is not possible (you do not have original project) and you purchase the same model of V350 maybe one option is present. You can reinstall old IO and main board to new V350. Usually I do not recommend doing it without experience, but as experienced engineers say - the eyes are afraid, but the hands can do it. 🛠️ 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 18, 2020 MVP 2023 Report Share Posted May 18, 2020 1 hour ago, kratmel said: You can reinstall old IO and main board to new V350. If you do this, be very careful to maintain battery power to the board at all times. 1 Quote Link to comment Share on other sites More sharing options...
phu.vu@ptt.vn Posted May 19, 2020 Author Report Share Posted May 19, 2020 7 hours ago, kratmel said: If screen damaged or touch sensor and program transfer is not possible (you do not have original project) and you purchase the same model of V350 maybe one option is present. You can reinstall old IO and main board to new V350. Usually I do not recommend doing it without experience, but as experienced engineers say - the eyes are afraid, but the hands can do it. 🛠️ Actually, Replace screen and key pads is not possible. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted May 19, 2020 MVP 2023 Report Share Posted May 19, 2020 8 hours ago, phu.vu@ptt.vn said: Actually, Replace screen and key pads is not possible. phu.vu, do you understand what Kratmel is suggesting in saying this? This might just be a translation issue. Or are you saying that the screen and keypads etc are all ok, and thus it is the main board etc that are faulty so changing them into a "new body" is not applicable in this case? It seemed to me that some clarification was necessary. cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 19, 2020 MVP 2023 Report Share Posted May 19, 2020 Moved this thread to the correct forum. Quote Link to comment Share on other sites More sharing options...
