phu.vu@ptt.vn Posted May 19, 2020 Report Share Posted May 19, 2020 Hi ! I have a vision series v350 and I want to backup all source (Hardware configuration, display, Ladder program,...) but I can't upload project from PLC. I think the option "Burn upload project" was not selected when the project was downloaded. Is there another way to backup PLC without upload source? Thank you so much! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted May 19, 2020 MVP 2023 Report Share Posted May 19, 2020 PhuVu, please do not post multiple times about the same issue. Also remember there is the delay before a moderator approves posts. Nearly all moderation on this forum is done by volunteers. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Isakovic Posted May 19, 2020 Report Share Posted May 19, 2020 Your best option is to contact the company/person that made the original program. If that is not an option contact Unitronics support directly. Or write program from scratch. If you can't get your hands on the program this is probably what has to be done. Quote Link to comment Share on other sites More sharing options...
