viscoelastic Posted May 22, 2020 Report Share Posted May 22, 2020 Say you have a 3 screens/modes, Manual, Semi and Automatic. 1) Would it be kosher to have a sub routine strictly to that screen/mode in focus to save scan time? 2) Under that circumstance would it still be bad practice to reuse coils that were in another routine even though they cant be called at the same time? 3) I would fear doing what I am saying would leave coils set when you change screens. I would have to write one long line of resets upon leaving? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted May 22, 2020 MVP 2023 Report Share Posted May 22, 2020 Visco, Joe recently answered this quite well here: http://forum.unitronics.com/topic/7081-subroutines/?do=findComment&comment=28796 The rest of the topic is a good read as well. Subs can be very tricky to implement properly unless you follow sequencing like he mentions. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted May 23, 2020 MVP 2023 Report Share Posted May 23, 2020 Also, don't forget that you can use NUM to BIT to reset a vector of MBs very easily, as long as you have them arranged in a vector order. cheers, Aus Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted May 23, 2020 Author Report Share Posted May 23, 2020 1 hour ago, Ausman said: Visco, Joe recently answered this quite well here: http://forum.unitronics.com/topic/7081-subroutines/?do=findComment&comment=28796 The rest of the topic is a good read as well. Subs can be very tricky to implement properly unless you follow sequencing like he mentions. cheers, Aus It sounds like he is doing something similar to me. In my mind subroutines seem so organized, but the more I read ,the more they seem like a pain in the aperture within the gluteal folds of ladder logic Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 23, 2020 MVP 2023 Report Share Posted May 23, 2020 My personal policy is to ALWAYS avoid conditional subroutines. There just isn't any good reason for them. Write your code so that every ladder rung is executed on every scan and you will avoid unnecessary grief. 17 hours ago, viscoelastic said: Under that circumstance would it still be bad practice to reuse coils that were in another routine even though they cant be called at the same time? In VisiLogic with Vision PLCs, you have 8192 coils. Are you running out? Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted May 23, 2020 Author Report Share Posted May 23, 2020 7 hours ago, Flex727 said: In VisiLogic with Vision PLCs, you have 8192 coils. Are you running out? No but you only have so many outputs. It just seems to get overwhelming and confusing have multiple coils calling one Output coil. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 23, 2020 MVP 2023 Report Share Posted May 23, 2020 There's no law that says you can't do it and the program will compile without errors, it just that experienced programmers consider it poor programming practice. There's a reason for that, but it doesn't mean it's impossible to be successful reusing coils in conditional subroutines. When you're the programmer you get to create your own style and technique. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted May 23, 2020 MVP 2023 Report Share Posted May 23, 2020 Everyone in the process of building a program in the Visilogic comes to their own style of writing. Therefore, we can come to the same action in our programs in completely different ways. In most cases, I have to test the program without having the whole system at hand. Therefore, for almost all types of panels, I wrote "my standard" routines for polling inputs and output control. This led to the idea that the activation of the output should be only in one place in the program - in this case, the subroutine OUTPUTS. Input polling is similar in another subroutine INPUTS. Values from inputs are overwritten into variables and used later in the program code. In this case i can add tesing MB for manual activation of input via online simulation. Each subroutine generates its own variable which should activate the output in the OUTPUTS subroutine only when the desired screen is active or the required condition is met. It is especially useful to see that the output is turned off by an emergency button or subroutine in one place. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted May 23, 2020 MVP 2023 Report Share Posted May 23, 2020 For what it's worth, I (almost) never use conditional subs. I only use subs to break up the Main Module into easily recognisable controls. Each one of these subs will likely generate quite a few MBs which relate to actual outputs, and I combine them in that sub to just one that is used further down in my outputs sub. Edit...The reason I do lots of MBs is so that I can actually see far more easily what is going on. If I use a common MB that is referenced many times through the ladder then it is a lot harder to find what is actually creating the condition it is currently in. Many people DO use the same MB to keep things "simple", but I often have so many things relating to a single output that without the separate MBs and conditions it can be very hard to track, as you only get to see the end result when online. I have said this before about programming, but Excel is your friend. It is easy to generate sheets with numbers, and it makes it much easier when you have such a ready reference. The descriptions in the sheet are more thorough than what is in my project. I describe them with both their name and a more complete "what, how, where" if necessary. However, conditional subs relating to screens do have their place if done properly. A crucial page to remember in help is this one. cheers, Aus Quote Link to comment Share on other sites More sharing options...
