mep23 Posted May 27, 2020 Report Share Posted May 27, 2020 I have had a new surface pro x (old one was surface pro 6) I have downloaded the vision software and all seemed to work fine, until I try and install the driver for the USB. then I get this message you have to run the 64 bit version of dplnst.exe on this machine. contact the vendor that provided you with this package . Anyone else had the same problem ?? Quote Link to comment Share on other sites More sharing options...
