KevB Posted May 28, 2020 Report Share Posted May 28, 2020 Hi, I am trying to produce basically a set of scales. Once the system is powered on and the bowl placed on top I would like to Tare the output. Here is an image of my ladder. Manually if I take the value now displayed in RealForce and enter it into ForceX1 my display goes to 0000. This is all good but now I am trying to find what I need to be able to do this by pressing a button on the screen. At present I am developing this on a USC-B10-TR22 but eventually will be transferring this to a V1210. Cheers KevB Leonardo Force Display.ulpr Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 28, 2020 MVP 2023 Report Share Posted May 28, 2020 Why are you using Real instead of integer? Quote Link to comment Share on other sites More sharing options...
KevB Posted May 28, 2020 Author Report Share Posted May 28, 2020 I used someone else's program and took the bits I wanted, and it worked, so to be honest I didn't think anymore about it. Quote Link to comment Share on other sites More sharing options...
KevB Posted June 8, 2020 Author Report Share Posted June 8, 2020 Thanks Flex727, that's much easier to understand now. I am still trying to get a Tare button working, I am applying a force to the load cell with a spring which I then need the user to be able to set the readout to 0. I know I need to input the value Force into Force X1 as when I do this manually my display zero's out, but I seem to be missing how to do this in the ladder. I have been unable to find any examples to look at so any help gratefully received. Cheers KevB Quote Link to comment Share on other sites More sharing options...
