Silvio Jorge Posted June 15, 2020 Report Share Posted June 15, 2020 Buen día: estoy desarrollando una aplicación con JZ20-31. Quisiera saber el uso del PID server para analizar el calentamiento de mi sistema. Como salida uso el PWM con relay. No logro entender de los tutorials como se lo utiliza. Muchas gracias Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 16, 2020 MVP 2023 Report Share Posted June 16, 2020 Unfortunately, the JZ20-R31 does not support PWM. It is a relay-output-only device and the Jazz series only supports PWM on models that have a High Speed Output (HSO). Even then your options are limited. If you upgrade to the Vision series (including Samba) you can use the PWM Scan function block to make any of the outputs have PWM behavior. Just be careful if you look at the Samba as the I/O count is not expandable. Joe T. Quote Link to comment Share on other sites More sharing options...
Silvio Jorge Posted June 19, 2020 Author Report Share Posted June 19, 2020 Gracias por responder. Creo que no me explique bien: estoy usando el ejemplo "PID with PWM relay output". Mi sistema reiquiere de AUTOTUNE y estudié el Ejemplo "PID M-91 Auto Tune". Entiendo que estas herramientas pueden funcionar en el Jz20-R31 Mi pregunta es si también puedo utilizar la herramienta PID SERVER, para realizar el AUTO TUNE. Gracias Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 19, 2020 MVP 2023 Report Share Posted June 19, 2020 I have not tried using the PID server with a Jazz, but you're not going to break it. Go for it and see if it works! Joe T. Quote Link to comment Share on other sites More sharing options...
