remy Posted June 20, 2020 Report Share Posted June 20, 2020 Hi, I have a question. I worked in Unilogic 1.26 with USP 070 For a project a need a slide button its possible to create ? Or it's existing in librairy Unipic but if its existing i don't find 😕 Thanks for you answer ! remy Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted June 20, 2020 MVP 2023 Report Share Posted June 20, 2020 This kind of thing is easy to create in Microsoft Paint. Here is what I created and use. You're welcome to use or modify as you see fit. Slide Switch Red_Left.bmpSlide Switch Green_Right.bmpSlide Switch Green_Left.bmpSlide Switch Red_Right.bmp Quote Link to comment Share on other sites More sharing options...
remy Posted June 20, 2020 Author Report Share Posted June 20, 2020 Hi ! Thank you so much for your share, i m going make a future slide button :)  Quote Link to comment Share on other sites More sharing options...
