remy Posted June 21, 2020 Report Share Posted June 21, 2020 Hi ! I work in unistream 1.26 For the next step, I need a make a login connection in web server, I don't know if it's possible ? In HMi, I found a management panel " Web Server password". Do I can use this for make a log in page ? Or I can use other method ? Thank you so much ! Quote Link to comment Share on other sites More sharing options...
Ofir Posted June 21, 2020 Report Share Posted June 21, 2020 Hello, Yes in order to create user authentication for the web server you should add roles and users. Then for each web page you can determine which roles are allowed to view this page. Quote Link to comment Share on other sites More sharing options...
