Samith Chathuranga Posted June 23, 2020 Report Share Posted June 23, 2020 My requirement is to connect & operate 6 HMI individually (Without mirroring) with PLC and the 6 HMI screens should view from computer remotely. I Hope to do it with Mqtt protocol or via Modbus. Please can someone help me to try this cos I have done only one project using Unistream PLC with Mqtt protocol previously. Please see the attached draft design of the project. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 23, 2020 MVP 2023 Report Share Posted June 23, 2020 If you get the Pro version of the PLC (-B10) you can serve your graphics up via the Webserver and achieve your dreams. The HMIs in this case are PCs running browsers. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
