Marten Posted June 24, 2020 Report Share Posted June 24, 2020 Hello, We have some strange things going on. Normally we use the Extension Module UAGXK300 module. However now we use the UAGXKPL1500 module for the first time. But some strange things are going on. Only change is this module. Sometimes, after some period, tags are being set/reset without an event. For example some alarms trigger occasionally, and the Reset button in the screen is not being reset. The way how this is written in the software is exactly the same as previous machines, which are many. All grounds are connected to each other. Please advice, Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted June 24, 2020 MVP 2023 Report Share Posted June 24, 2020 You need to post more information about hardware configuration. You must use this manual for configuration https://unitronicsplc.com/wp-content/uploads/2019/08/SPEC_UAG-XK_XKP_-XKPLxxxx_UAG-CX-XKPxxx.pdf Maybe some part of your hardware combination is not recommended, please see this table in above From this manual: When daisy chaining, you can include only 1 Long -range adapter. You may connect it directly to the controller or to any of the elements that are expanded from it. Quote Link to comment Share on other sites More sharing options...
