Inbashable Posted June 26, 2020 Report Share Posted June 26, 2020 Hey, Im trying to use the Analog Input on my V350. Even if i assign a MI to the Input in the Hardware, the value stays zero? The voltage on the input is between 8.2v and 10v, so in the specs. Any ideas why this isnt working? If the sensor isn't in use, the input is connected to 0V. Is this ok? Best Regards Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted June 26, 2020 MVP 2023 Report Share Posted June 26, 2020 Have you got ALL power connections done properly according to the 350 manual's wiring diagrams? Analogue stuff won't work unless their specific power connections are done. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Cam Posted June 26, 2020 Report Share Posted June 26, 2020 Also check that your jumpers are set correctly. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted June 26, 2020 MVP 2023 Report Share Posted June 26, 2020 Hi, is it jumper settings in correct position? Input default is Digital! Quote Link to comment Share on other sites More sharing options...
Inbashable Posted June 27, 2020 Author Report Share Posted June 27, 2020 Thanks to you all, didnt know there we're jumpers! RTFM i'd say 😅 Quote Link to comment Share on other sites More sharing options...
