CobryWZL Posted June 30, 2020 Report Share Posted June 30, 2020 Hi guys, I recently asked myself, if theres a possibility to read NFC tags using a SAMBA PLC. Usually NFC readers have a USB interface and need a PC to read the information on a NFC tag. Did anybody ever try to use a SAMBA or other Unitronics PLC instead of a PC to read NFC information? Is there any hardware you can recomment? Best regards Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 30, 2020 Report Share Posted June 30, 2020 Vision PLCs has USB-A or USB-Mini interface, which can be used only for programming, or online communication with PC. Vision PLCs does not support external USB devices. You have to find NFC reader with RS232 or RS485 interface - then you canm use it with PLC. B. R. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted June 30, 2020 MVP 2023 Report Share Posted June 30, 2020 Hi, maybe best solution is to use Ethernet card and connection to the Samba. Device like this https://minovatech.de/mcr08-nfc-rfid-hf-en.php has Ethernet, RS232 and 485 port present also. Quote Link to comment Share on other sites More sharing options...
Cam Posted June 30, 2020 Report Share Posted June 30, 2020 RFIdeas has readers with RS232 interfaces. Quote Link to comment Share on other sites More sharing options...
