sanyc Posted July 14, 2020 Report Share Posted July 14, 2020 Hi, Does anyone know how I can interface the following joystick to a Unistream? Thanks MR Series Specifications.pdf Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 14, 2020 Report Share Posted July 14, 2020 Hi, Use voltage divider and analog inputs 0-10V. For buttons use digital inputs. B.R. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted July 14, 2020 MVP 2023 Report Share Posted July 14, 2020 Hi, if joystick used for control motion application - you need: 1) setup DC/DC 24VDC to 10VDC or use linear L7810 (or other IC) based 10V refrence. 2) use GND to Rdown+Rpot+Rup to10V ref serial connection. Rdown and Rup 0.25w resistors. For example 0.5k + 5k axis + 0.5k = 6k resistanse for each axis. 3) connect all axis joystick output to 3 analog input of PLC. 4) program code for test ADC readout for DOWN, ZERO, UP position of all axis. DOWN is abow 0V and UP is below 10V for safety. 5) set for all axis error condition if ADC is not in DOWN to UP readout range. This is used to stop motion if joystick or wire is broken. 6) program code for ZERO set for all axis (+- tolerance) and program joystick test when PLC is power up. In robots if one of joystick axis is not in ZERO after start - all motion is desabled. 7) use linearisation for calculate axis speed refrence for ZERO to DOWN and ZERO to UP and generate axis direction signal. You can do simple (not safe) connection without DOWN UP resistors. But if someting wrong with joystick or wire you axis can move uncontroled at maximum speed and direction is hard to predict. If spare ADC channel present - you can manage 10V reference check for safety - if joystick power lost you can disable application before uncontrolled motion happend. Quote Link to comment Share on other sites More sharing options...
