berndp Posted July 22, 2020 Report Share Posted July 22, 2020 I have time schedules programmed and they generally work fine. (Version 1.28.26) However, when wanting to run 24hrs/day, I set the from time at 00:00, and the to time 23:59. The schedule actually switches off at the start of minute 59 (at 23 hours). It should switch off at the end of minute 59, which is equal to the start of minute 00 (of hour 00 the next day). Has this been fixed in a newer version (1.29.111)? If not, please fix it. Thanks Bernd Quote Link to comment Share on other sites More sharing options...
sgull Posted July 22, 2020 Report Share Posted July 22, 2020 Hi Bernd I think this behavior is correct. For example if you want to run from midnight for 1 minute you set the start for 00:00 and end at 00:01. It runs for 1 minute and stops at the start of 00:01. If it ran to the end of 00:01 it would have run for 2 minutes The problem is that the schedule does not allow you to enter seconds. If you want to run for 24 hours set the start to 00:00 and the end to 00:00 Denis Quote Link to comment Share on other sites More sharing options...
berndp Posted July 22, 2020 Author Report Share Posted July 22, 2020 Hi Denis, I will try the 00:00 > 00:00, hoping it won't just remain off 🤔 Quote Link to comment Share on other sites More sharing options...
berndp Posted July 22, 2020 Author Report Share Posted July 22, 2020 So, that 00:00 > 00:00 setting did work, thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted July 22, 2020 MVP 2023 Report Share Posted July 22, 2020 It is confusing berndp, isn't it? Across different PLC species you get varied responses to this sort of instruction. @Cara Bereck Levy Maybe better wording in the descriptions would help? cheers, Aus. Quote Link to comment Share on other sites More sharing options...
berndp Posted August 6, 2020 Author Report Share Posted August 6, 2020 So, although the 00:00 > 00:00 setting works to run for 24hrs, it seems that there still is a gap between "23:59:59" and 00:00, where the schedule is off. I will investigate further, to see how long this gap may be. For now I "bridged" this problem with a delay-off timer, but that is surely not the correct solution. Any ideas? As far as "version" is concerned, this is a bit confusing. Unilogic shows V1.29.111, yet firmware manager shows 1.29.133 ? How does this work? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 6, 2020 MVP 2023 Report Share Posted August 6, 2020 2 hours ago, berndp said: Unilogic shows V1.29.111, yet firmware manager shows 1.29.133 ? How does this work? There are a lot of different files that make all of this work. They are not all updated at the same time. There is no reason the versions numbers would remain in sync. Quote Link to comment Share on other sites More sharing options...
berndp Posted August 6, 2020 Author Report Share Posted August 6, 2020 OK Thanks Quote Link to comment Share on other sites More sharing options...
