Vesp123 Posted July 23, 2020 Report Share Posted July 23, 2020 Hey guys, I am looking for alternative to PLC Vision V1040 that I have been using for few years. I mostly used it without a snap, but with connection to additional I/O, because my needs forced me to separate PLC from control panel so I am not interested in Unistream Modular but rather Unistream Built in or Unistream PLC with Virtual HMI. However I would like to still use a 10 inch screen. My questions: 1. Why Unitronics did not provide USL-010 (Unistream Display) or US10(Unistream Built-in) screens? 2. Maybe graphic is much worse when sb tries to use Unistream PLC like e.g. USC-B10-XXXX with a 10 inch screen? Did someone of you check how such configuration(Unistream PLC + 10 inch screen through VNC) would look like? I am looking for your replies, Thanks in advance Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted August 26, 2020 Report Share Posted August 26, 2020 I would check the aspect ration of whatever "screen" (tablet with VNC viewer) and match that as close as possible to the screen. For instance I would go with the low cost Unistream 7" with a 16:9 aspect ratio and find a 10"ish tablet with that ratio. Scaling is done through the VNC viewer on the tablet. I use RealVNC as a VNC viewer and the scaling can be adjusted in the properties of the connection. On the Unitronics website I see: 7" 16:9 10.4" 4:3 15.6" 16:9 -Swervomotor Quote Link to comment Share on other sites More sharing options...
DanT Posted August 31, 2020 Report Share Posted August 31, 2020 Hi; The USP-104-B10 10 Inch HMI and USP-156-B10 15 Inch without the CPU Module attached will act as a remote HMI via VNC. The CPU Module is required for the PLC program, so the Screen is focused on the HMI and other communications. DanT Quote Link to comment Share on other sites More sharing options...
Vesp123 Posted September 15, 2020 Author Report Share Posted September 15, 2020 Thanks for ur answears guys. I didn't know about the possiblity of changing graphic resolution - as it turned out graphic was not a problem, silly me Recently, I figured out that there are new 10' and 15' Unitronics screens from USL series (USL-101-B05 and USL-156-B05) so my problem was solved. Quote Link to comment Share on other sites More sharing options...
Zact Posted October 22, 2020 Report Share Posted October 22, 2020 So, the 10 and 15 inch USL series HMIs can connect to VNC through ethernet without the cpu? I'm looking for a solution like this, but didn't realize the HMI came with rj-45 ports. Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted October 22, 2020 Report Share Posted October 22, 2020 1 hour ago, Zact said: So, the 10 and 15 inch USL series HMIs can connect to VNC through ethernet without the cpu? I'm looking for a solution like this, but didn't realize the HMI came with rj-45 ports. Pretty sure the 7" will as well. The HMI houses 2 rj45, 2 usb host, 1 usb device, audio jack, micro sd card. The CPU has RS485 and CANBUS. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 23, 2020 Report Share Posted October 23, 2020 Hi All, A new 10.1" models required by Vesp123 already at site! Visit and review! B.R. Quote Link to comment Share on other sites More sharing options...
