damiankk Posted July 27, 2020 Report Share Posted July 27, 2020 Hi, I'm not sure about phrase in manual of URB-TCP, which says:"The adapter is limited to process 192 data bytes for inputs and 192 data bytes for outputs." Does it mean thah when I use 192 bytes as inputs, I can still use 192 bytes for outputs? Please let me understand it well, Greets, Damian Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted July 28, 2020 MVP 2023 Report Share Posted July 28, 2020 15 hours ago, damiankk said: Does it mean that when I use 192 bytes as inputs, I can still use 192 bytes for outputs? That's how I read it. Then for grins I loaded one up with (6) 16 point analog inputs and (6) 16 point analog outputs. That's 192 bytes each way: It compiled with no errors. Try playing with different configurations on your own. You're not going to break the software, and it will certainly tell you when you've screwed up. Just like people. 😁 Joe T. 2 Quote Link to comment Share on other sites More sharing options...
