Pavel M Posted July 28, 2020 Report Share Posted July 28, 2020 Hello I want to add some visualisation to my project, so i have some questions: is that possible to make Variable: Bargraph to change its fill colour when it reaches some value? Or, is that possible with Variable: Meter make ranges (From-To) not as constant values, but as variables? The problem is: i want to show productivity as a Meter and Temperature as a Bargraph, but my productivity is not a constant value, every time i set some productivity as a parameter i want to cut some from my possible maximum and from my possible minimum. Same with temperature, i have temperature as a parameter and i have some working range, so i want just to show, for example, my current temperature and working range +- 5 degrees and if my temperature out of range or close to be out of range - show it with different colour. Or do i need to use some extra pictures like lights to properly show it? Thanks and sorry for bad English Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted July 28, 2020 MVP 2023 Report Share Posted July 28, 2020 Hi, you can select non constant min max in bargraf. But you must check in program is it this limit correct . For example - is it min < max. Quote Link to comment Share on other sites More sharing options...
