asabiski Posted July 30, 2020 Report Share Posted July 30, 2020 Boss and I were talking and we have a customer that may want to use a plc as both a master to a temperature controller and a slave to another display/plc. Hypothetical at this point, but can I use a vision plc as both master and a slave? Desire would be to do RTU (RS485) at this point but IP might be possible. Thanx Allan Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 30, 2020 MVP 2023 Report Share Posted July 30, 2020 You absolutely can with MODBUS TCP/IP. Just use two different sockets. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted July 30, 2020 MVP 2023 Report Share Posted July 30, 2020 You can find V570 Modbus loopback test.vlp at Visilogic help/Example/Communication/Modbus. Two port using for both - Master and Slave in one PLC Quote Link to comment Share on other sites More sharing options...
