Vinicius Posted August 5, 2020 Report Share Posted August 5, 2020 Hello, I would like to know if there is someway to connect a TV to a PLC Samba SM35-J-TA22 to display variables? Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 5, 2020 MVP 2023 Report Share Posted August 5, 2020 You can run Remote Operator on a Windows computer and put the computer display on a TV. Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted August 5, 2020 MVP 2023 Report Share Posted August 5, 2020 Tested solution SAMBA + mTV-100 device. Installed on production line as large process monitor. Connection via modbus. https://dl.weintek.com/public/mTV/eng/Datasheet/mTV_100_Datasheet_ENG.pdf Quote Link to comment Share on other sites More sharing options...
