m_a_s001 Posted August 5, 2020 Report Share Posted August 5, 2020 Hello!, my name is Mario and I ask if someone can please help me with my problem. I try to control a Sinamics G120 with a V350 via modbus RTU, but I can´t do it! The connection of between the PLC and the V350 is: V350 (jumper set "RS485" - Jumper TERM: off) Port 1 - Pins: 1 and 6 Sinamics G120 X128: terminals 2 and 3 Configuration of the project: Sinamics G120 (Starter): V350 (Visilogic) I tried to change some parameters of the communication, but the problem never disappear (status message=5). If somebody can give me some help I will be very grateful! Best Regards Mario Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted August 5, 2020 MVP 2023 Report Share Posted August 5, 2020 Maybe this document is useful https://cache.industry.siemens.com/dl/files/623/109764623/att_978241/v1/109764623_G120C_Modbus-communication_DOC_V10_en.pdf Please see STW1-control and ZSW1-status address. 40100- control byte 40101-setpoint. Also try to swap RS485 wires. P/S Maybe you try to setup V350 PORT 1 as Modbus and at the same time - try to monitor communication via USB port connected to SAME PORT 1. You need to use Ehternet card for connect to Visilogic or install add PORT2 RS485 com card as MODBUS com2 for use USB cable as connection to Visilogic Quote Link to comment Share on other sites More sharing options...
m_a_s001 Posted August 6, 2020 Author Report Share Posted August 6, 2020 23 hours ago, kratmel said: Maybe this document is useful https://cache.industry.siemens.com/dl/files/623/109764623/att_978241/v1/109764623_G120C_Modbus-communication_DOC_V10_en.pdf Please see STW1-control and ZSW1-status address. 40100- control byte 40101-setpoint. Also try to swap RS485 wires. P/S Maybe you try to setup V350 PORT 1 as Modbus and at the same time - try to monitor communication via USB port connected to SAME PORT 1. You need to use Ehternet card for connect to Visilogic or install add PORT2 RS485 com card as MODBUS com2 for use USB cable as connection to Visilogic I checked what you indicated, but all was ok, and I still have the problem.... I added a ethernet port and I can see that the status messages is in "4". It´s is possible that the end resistor was the problem? Thanks for your Help!! Best Regards Mario Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted August 6, 2020 MVP 2023 Report Share Posted August 6, 2020 Please see correct MODBUS addresing for G120 https://cache.industry.siemens.com/dl/files/159/99685159/att_83708/v1/G120_Field_busses_FH17_0414_eng_en-US.pdf You use 111 address for reading, maybe it is wrong. Please see on p.101 modbus telegram format and use correct 110 as equal to address 40111 (for 40110 used 006D hex = 109 dec in telegram example) 1 Quote Link to comment Share on other sites More sharing options...
m_a_s001 Posted October 7, 2020 Author Report Share Posted October 7, 2020 On 8/6/2020 at 5:23 PM, kratmel said: Please see correct MODBUS addresing for G120 https://cache.industry.siemens.com/dl/files/159/99685159/att_83708/v1/G120_Field_busses_FH17_0414_eng_en-US.pdf You use 111 address for reading, maybe it is wrong. Please see on p.101 modbus telegram format and use correct 110 as equal to address 40111 (for 40110 used 006D hex = 109 dec in telegram example) That was the problem!!! Thanks!!!! Quote Link to comment Share on other sites More sharing options...
