Guest JimP Posted August 13, 2020 Report Share Posted August 13, 2020 Where do i find, or download UniApps? Quote Link to comment Share on other sites More sharing options...
NoamM Posted August 26, 2020 Report Share Posted August 26, 2020 Dear Guest JimP,UniApps comes pre-installed on a UniStream. Hold your finger in the upper right corner of the screen and press "UniApps" Quote Link to comment Share on other sites More sharing options...
NutzlosNorm Posted September 7, 2020 Report Share Posted September 7, 2020 What about when there is no screen as with my USC-B10-B1? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted September 7, 2020 MVP 2023 Report Share Posted September 7, 2020 I spoke to Norm on the phone and determined that he is trying to update the firmware on his USC-B10-B1. You need to create an additional file called an "Action file" on the USB drive to do this. There is a detailed procedure in UniLogic Help. Here's where to find it: Search "PLC firmware" Select Rank number 3 - "UniStream PLC (PLC without HMI Panel). The directions to create Action files are here. Joe T. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted September 8, 2020 Report Share Posted September 8, 2020 17 hours ago, NutzlosNorm said: What about when there is no screen as with my USC-B10-B1? Access remotely by VNC and access UniApps at Virtual Display. B.R. Quote Link to comment Share on other sites More sharing options...
