V700 Posted September 13, 2020 Report Share Posted September 13, 2020 I have a V700 with V200-18-E3XB module and i want some help to connect the sensor of the photo. (I already set the jumpes to current, i connect 24Vdc from my power supply to the red wire of the sensor.) Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 13, 2020 MVP 2023 Report Share Posted September 13, 2020 Unitronics provides a spec / installation document to help with this. Here is a screen cap of the relevant protion: Since you appear to have a 3 wire sensor utilizing current, use the diagram on the lower left. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted September 13, 2020 MVP 2023 Report Share Posted September 13, 2020 As i see on cable pic. - this sensor is two-wire. RED wire connect to +24V (+V) of power supply. Blue/green wire to ANALOG input (4..20mA). Black wire to GROUND (Earth). -24VDC (0V) of power supply connect to ACM. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 14, 2020 MVP 2023 Report Share Posted September 14, 2020 19 hours ago, kratmel said: As i see on cable pic. - this sensor is two-wire. Yes, you are correct. Quote Link to comment Share on other sites More sharing options...
