Data from OPLC to share drive on network
CatUnitronics
Have a USP-156-B10 and a data table Index that stores the test results up to 100 rows. We then have to use an application to get those results and save the data to a text file. From the text file, we put it to an excel spreadsheet and sort. From there it goes to another text file to import it to a spreadsheet which we have formatted. After formatting on the PC, we then put it on a share drive to where the data is kept.
Been assigned a task to put the data results to the share drive from the Unitronics. So far I can only see how on getting the results to an SD card and from there I would like to send to the server.
Any suggestions??
Thanks
