Milosh Posted September 15, 2020 Report Share Posted September 15, 2020 Hi all, How to copy, memory long integers (32bit) to memory integer (16bit)? Or, how to split memory long integer to two memory integers? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Milosh Posted September 15, 2020 Author Report Share Posted September 15, 2020 1 hour ago, Milosh said: Hi all, How to copy, memory long integers (32bit) to memory integer (16bit)? Or, how to split memory long integer to two memory integers? Thanks in advance I figure it out. I use COPY MEMORY function to do it... Quote Link to comment Share on other sites More sharing options...
