Mickael Posted July 21, 2011 Report Share Posted July 21, 2011 Hello, I have a little question about the SI58 The value of my SI58 is 1024 but i think that this must be 1 to 10 is it ? Thanks Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted July 21, 2011 Report Share Posted July 21, 2011 Hi, You're right. There is a mistake in the description. The range of SI 58 is 1-1024 where each unit equals 10k. Therefore, the actual size range is 10k - 10M. We are changing the description. Thank you for pointing it out. Quote Link to comment Share on other sites More sharing options...
Mickael Posted July 21, 2011 Author Report Share Posted July 21, 2011 Ok thank's So I have a problem to send a .csv to email The size is aprox 3Mo and the file is not send only a part But i have no error ? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted July 21, 2011 Report Share Posted July 21, 2011 Hi Mickael, Which Visilogic version are you using? Which OS installed on the PLC? Please make sure you are using the latest VisiLogic 9.3.0 and the latest OS versions. Are you sending the email over Ethernet or GPRS? Quote Link to comment Share on other sites More sharing options...
Mickael Posted July 21, 2011 Author Report Share Posted July 21, 2011 I'm using visilogic 9.0.1 OS installed is 3.3 E.mail are send over ethernet Thanks Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted July 24, 2011 Report Share Posted July 24, 2011 Try installing OS v3.4 (01). Upgrade to VisiLogic 9.3.0. Let me know the results. Quote Link to comment Share on other sites More sharing options...
Mickael Posted July 26, 2011 Author Report Share Posted July 26, 2011 OK I will try Thanks Quote Link to comment Share on other sites More sharing options...
Mickael Posted July 28, 2011 Author Report Share Posted July 28, 2011 Now it's OK I can't mail a file who was corrupted (created date of the file 01/01/0001 ) i have formated the SD and now it's OK Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted June 14, 2013 Report Share Posted June 14, 2013 Description of SI58 hasn´t been fixed Quote Link to comment Share on other sites More sharing options...
