yewtech Posted September 4, 2010 Report Share Posted September 4, 2010 Hi In the Graphic, we are not able to select the decimal point (Base Format) in the Varibale Numeric Format when we are using MF (Floating address) in the LINK. Please kindly advise. It would be good that we can able to decide the decimal point when we using MF for display purpose. Quote Link to comment Share on other sites More sharing options...
Emil Posted September 5, 2010 Report Share Posted September 5, 2010 Decimal point is part of MF register. It's displayed on its place! Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted September 5, 2010 MVP 2014 Report Share Posted September 5, 2010 Hello Emil, This is the old "can we round off MF values for display" question. yewtech, At this stage probably the easiest method is to use the "num to ASCII" and set the number of decimal places there, then display the value as ASCII. If you need keypad entry then the other option is to split the number in to two MI values and disaply them with a decimal point in between. Quote Link to comment Share on other sites More sharing options...
