Stefan Oosterbosch Posted September 4, 2010 Report Share Posted September 4, 2010 Hello, I tried to create a file on a SD Card in a vision V350. I used the functions "SD Utility Delimited Line" and "Write -> SD Delimited Line". The format of cells I was trying to enter were: String (RTC To ASCII) and an integer (MI). The creation of the CSV file worked, but all on one line. I was logging every 10 seconds, but all logdata is entered with the same delimiter on the same line. In the help files I could not find anything about starting a new line. How to create a .csv file with multiple lined of logdata? Regards, Stefan. Quote Link to comment Share on other sites More sharing options...
Ofir Posted September 5, 2010 Report Share Posted September 5, 2010 Hi Stefan, If you wish each log to create a new line - set in the last row of the function "Create Delimeted line" the delimiters as CR and LF. \You can take a look at the example "SD_Card_Demo" in Unitronics Examples under SD folder. Quote Link to comment Share on other sites More sharing options...
