Damian Posted September 8, 2011 Report Share Posted September 8, 2011 Are there any plans on making the canned alarm screen pop-ups sized properly for the V1040? Right now, because of the resolution, It even smaller than it is on the V570. This is VERY difficult to explain to customers. And ........... If it is going to stay a small "sub-window" pop up, it really needs to have some sort of border. The background color of the alarm pop-up just happeded to be the same background color I used o each and every one of my screens (the default). Now when the alarm screen pops up it looks bad because it blends in with my background and just blotches out whats behind it. A border would at least give it a sense of being a window. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted September 11, 2011 Report Share Posted September 11, 2011 Hi Damian, I hear you about the size. The issue has been raised, and I will raise it again. In the meantime, we have added this SB, and I hope it is of use: SB 249: Black Background. Applicable when a system screen such as Alarm or Info does not stretch across the entire screen. Set /Reset By user application Takes effect when screen is refreshed. 1 Quote Link to comment Share on other sites More sharing options...
Damian Posted September 11, 2011 Author Report Share Posted September 11, 2011 Hi Damian, I hear you about the size. The issue has been raised, and I will raise it again. In the meantime, we have added this SB, and I hope it is of use: SB 249: Black Background. Applicable when a system screen such as Alarm or Info does not stretch across the entire screen. Set /Reset By user application Takes effect when screen is refreshed. Hi Cara, SB249 was a big help! I like that a lot better. Thanks, Damian Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted September 12, 2011 Report Share Posted September 12, 2011 Cool :-) I must admit that although it was in the system operand list, it wasn't in the Alarm topic--it is now! Quote Link to comment Share on other sites More sharing options...
Damian Posted September 12, 2011 Author Report Share Posted September 12, 2011 Hi Cara, There is no description for SB249 yet in the operand table. At least not in my version of Visilogic. That might help as well. But now I must ask, why not let the OS take care of this automatically? I can't see any reason why you wouldn't want SB249 to be set all the time. Thanks, Damian Quote Link to comment Share on other sites More sharing options...
