Wambo Posted September 28, 2011 Report Share Posted September 28, 2011 Hi All I am unable to initialize Enfora 1308 on Com port 1 with V130 . I have only one port 1for program download and connect to modem. I have successfully initialize the modem with the PC. I do not know much about the modem commands so I copied the commands from the PLC modem prepare to Com 1 Init. I am using SB 80 and SB 81 on the HMI to check but it has failed to initialze. Can somebody help me with what I am not doing correctly, probably the commands on Com 1Init? regards Wambo Com init.vlp Quote Link to comment Share on other sites More sharing options...
TT_ZX Posted September 29, 2011 Report Share Posted September 29, 2011 Try using a baud rate of 9600. See here for more information: My link Quote Link to comment Share on other sites More sharing options...
Guest Jan N. Posted September 29, 2011 Report Share Posted September 29, 2011 Hi Wambo! Have You tried to power up the modem and plc at the same time while they are connected to each other? Have You tried to use the default init strings in Com init block for enfora? What about the modem vs plc connecting cable. As long as I know the preparation cable and modem vs plc cable are different. Somebody can confirm that maybe. Jan Quote Link to comment Share on other sites More sharing options...
Jas Posted September 29, 2011 Report Share Posted September 29, 2011 Try using a baud rate of 9600. This poster is correct. As of recent, Vision controller operating systems now mandate the use of 9600 baud rate for the Enfora modem. It used to be the case that any speed would work, and actually 57,600 was the most common to use. This is no longer true, and you must re-prepare the PLC side modem for a 9600 baud rate as well as have this set in the COM Init function block. Quote Link to comment Share on other sites More sharing options...
