JohnnyB Posted October 15, 2011 Report Share Posted October 15, 2011 Hi Guys In Build menu - Project Memory Map show size of my application using color bar´s. I finish the complet routines for one input, howover i have more 130 inputs for config. I'm worried that space using at this moment. How i can view the size of application in bytes ? I using the Visilogic 9.3.1 Build 0 - And V130 - 33-T38 with 08 IO-DI16 / Windows 7. Thanks for attention. Quote Link to comment Share on other sites More sharing options...
