thanatos Posted November 2, 2011 Report Share Posted November 2, 2011 I want to do communication between a v1040 and a slc5/4(os401) with df1. I try the parameter that I find in the exemple, the only difference is that I dont use a compact logic cpu but a slc500. The write function is working but the read function doesnt work at all. The communication is very unstable, I lost a lot of packet. I dont know if the problem is that my os in the slc500 is to old or if I did a bad configuration but I have a lot of problem. The other problem is that when I change the chanel configuration in the slc500 like it was in the exemple, after the download, I am not able to communicate anymore with the slc500 using rs-link. I want to know I it is possible to communicate in df1 between these two plc and if someone have the parameter that I have to put in rs-link, slc500 and v1040? Quote Link to comment Share on other sites More sharing options...
Damian Posted June 11, 2012 Report Share Posted June 11, 2012 Sorry for the late reply, were you ever able to figure this out? Quote Link to comment Share on other sites More sharing options...
