PBtec Posted May 19 Report Share Posted May 19 Hello all, I have two tools that use a USP-070-B10 for a PC controller and I need to pull process logs off of the tools over a network. What would be the best way to setup a file transfer system and how would I set this up? Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted May 19 MVP 2023 Report Share Posted May 19 I'd use an Indexed Data Table to create the logs and then use the Store DTI to File function block to create a csv file on the SD card. You can then enable the FTP server and retrieve them from an external PC. Joe T. Link to comment Share on other sites More sharing options...
