JFS Posted June 22 Report Share Posted June 22 Hello. I have HMI VISION 350 tr35 and the visilogic 9.8 software in Non-Administrative version to be able to work with my PC and the IT department is not a problem. This NON-ADMINISTRATIVE version works correctly, but RUN TIME DOES NOT WORK (error run time 13). I can handle the software correctly without administrator powers but the run time gives me error 13 and I can't do online tests with HMI VISION 350. Does anyone know anything about this? Is there a Non-Administrative swapper version without administrative powers? Is there a Non-Administrative run time version without administrative powers? Thank you in advance, best regards. Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted June 22 MVP 2023 Report Share Posted June 22 @Saragani something for you to further pursue for JFS........ you might recall this thread etc: https://forum.unitronics.com/topic/10248-get-version-95-or-93-of-visilogic/?do=findComment&comment=44054 cheers, Aus Link to comment Share on other sites More sharing options...
JFS Posted June 22 Author Report Share Posted June 22 Hello again. Ausman, in the previous post I mean that I can open any type of visilogic version with my NON-ADMINISTRATIVE version of visilogic, I open any project and modify and download without any problem everything is fine. The problem happens when I try to do ONLINE tests with my HMI VISION 350 the RUN TIME of the NON-ADMINITIVE version of visilogic gives me "error 13". The question is if the visilogic run time is out of the non-ADMINISTRATIVE visilogic software and that's why it won't let me connect ON LINE? Everything else works correctly, I open projects, modify and download without incident with the NON-ADMINISTRATIVE version of visilogic. Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted June 22 MVP 2023 Report Share Posted June 22 JFS, I understand all you are saying, but it is a problem for the creators, hence my alerting Saragani. This issue is not one for the many volunteers here to help solve. cheers, Aus Link to comment Share on other sites More sharing options...
