justsmurfted Posted August 26 Report Share Posted August 26 Hi _ Wonder if anyone is able to help me please. I am learning (self) and have a basic system at home. I was hoping to be able to have the input value (B) of each of these lesser than functions on the hmi screen so they can be altered without the software - is that possible ? Thanks Link to comment Share on other sites More sharing options...
ORSO2001 Posted August 26 Report Share Posted August 26 hi justsmurfted, yes it is possible...as for the "A" input you can couple a variable/tag that will be also coupled with an HMI element, like numeric box, so you will able to modify it when you want...pay attention at the "retained" or "not retained" type and at its attribute "starting" or "power up" value. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 26 MVP 2023 Report Share Posted August 26 Looks like you're creating a thermostat for your pool temperature. The way I would do it is to create a tag for the temperature setpoint (this will be the value displayed on the HMI that can be modified), then create two more tags that you add and subtract half the variance you allow around the setpoint. Place these tags in your two compare blocks for the 'B' value. If you want to have a fractional degree variation, you will need to multiply everything by 10 so that you can have an implied decimal to work with. Link to comment Share on other sites More sharing options...
justsmurfted Posted August 26 Author Report Share Posted August 26 2 hours ago, Flex727 said: Looks like you're creating a thermostat for your pool temperature. The way I would do it is to create a tag for the temperature setpoint (this will be the value displayed on the HMI that can be modified), then create two more tags that you add and subtract half the variance you allow around the setpoint. Place these tags in your two compare blocks for the 'B' value. If you want to have a fractional degree variation, you will need to multiply everything by 10 so that you can have an implied decimal to work with. Thanks Flex727 - yep absolutely correct. Ideally like to keep the pool around 29 ish but would be good to be able to up that as needed. I think I interpret you correctly - > Sorry - just so I get it spot on - on this basis below. Heatvalve comes on at between 27deg and 31deg ? The numeric box on the hmi works perfectly - thankyou! Basic I know but am getting there slowly. 😊 Link to comment Share on other sites More sharing options...
justsmurfted Posted August 26 Author Report Share Posted August 26 5 hours ago, ORSO2001 said: hi justsmurfted, yes it is possible...as for the "A" input you can couple a variable/tag that will be also coupled with an HMI element, like numeric box, so you will able to modify it when you want...pay attention at the "retained" or "not retained" type and at its attribute "starting" or "power up" value. Thanks ORSO2001 - i think coupling a tag at the moment is beyond me. Appreciate your reply. Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 26 MVP 2023 Report Share Posted August 26 1 hour ago, justsmurfted said: Sorry - just so I get it spot on - on this basis below. Heatvalve comes on at between 27deg and 31deg ? No, you're trying to do math with a compare function block. That won't work. You need to create two new tags using the addition and subtraction function blocks, then use those tags in the compares. Link to comment Share on other sites More sharing options...
