Posted
Hi All,
I am new to this Unitronics PLC after downloading the backup PLC program to new PLC. PLC show in idle mode, how to change it to "Run" mode.
My current PLC when turn on it will go straight to launch it program. Can anyone give me some guidance how to solve these issues.
Posted
Hi kratmel,
Am I doing correctly, very new to this PLC and this software. I had been playing it for last few days. Trying to add a line to it as all of you mentioned.
Thanks God, managed to find it command and created a Net. Did I write it wrongly.
Please give me some advice and guidance.
  • MVP 2023
Posted
Rather than assigning a powerup value to SI 253 and copying it itself, try using the official "Set Info Password" block from an MI that has a powerup value-
Posted
Hi Joe,
Due to MB500 was assigned for other use, can I assign it to other empty MB. I had assigned it to MB1021, any other things I needed to do after that.
Do I need to key in any password whenever I turn on PLC ?
Thanks and Regards
  • MVP 2023
Posted
Any MB will do, as will any MI.  That's just an example picture.
No, you don't need to enter a password to start the PLC.  The password is for when you go into Info Mode, which is accessed by holding the touch screen.
  • MVP 2023
Posted
11 hours ago, Ausman said:
the  password must be 4 different digits  ie  1234 ok   1133 not ok
Is this true? I thought it couldn't be 4 of the same, not that all 4 must be different.
I'll test this today when I get a chance.
  • MVP 2023
Posted
That's why I said "apparently, going on other info becoming known".......
This bit of info arrived from the creators a little while ago in private messaging:
You are no longer able to have the info mode password be the same number 4 times, for example "1111" or "2222" ect. It must now be a combination of 4 numbers.
I have not tested it as yet, so Flex, please do so.  If it is true, it goes a long way to explaining why some users have had no issues, because they already use the "combination" as part of their overall security strategy.  Other examples we've seen where users have issues, we have seen some repeated digits.
Lastly, I think that an "incorrect" info mode password creating stop conditions on boot seems a bit of overkill, given what info does.
cheers, Aus
Posted
Hi Guys,
Thanks for the guidance, managed to get PLC in running mode. I have not hook up to my current machine to test under all function. Will post if all went well after hook up to test actual running.
Thanks and Best Regards
Shalom (Peace)
Register a new account
Sign in
Important Information
