MVP 2023 Flex727 Posted September 24 MVP 2023 Report Share Posted September 24 I am developing a project with a USC-B5-B1 PLC using UniLogic 1.33.373. I want this PLC to be a Ethernet/IP Adapter (Target) and provide data that is organized as a vector of 30 bits that it has collected from elsewhere. When I try to create the Adapter Node, I get an error message in the Output Size column that says "Mismatch: a bit vector must be in multiples of 8 to accommodate bytes." What would be the best or proper way to set this up? Do I need to copy the data to 4 other vectors of 8 bits each, or just list each of the 30 coils individually, or what? It will not let me select a single element of the vector. (Edited to add screen cap) Link to comment Share on other sites More sharing options...
Dave Posted September 25 Report Share Posted September 25 I think it may be easier to manipulate the data at the other end, if each coil had an integer associated with it. Coil is OFF, write 0 to integer(INT8). Coil is ON, write 1 to integer. Reverse the operation at receiving end to get back to bit data. Its a bit more code to write, but not to complicated. After some more thought.....while I think that should work, I don't think its the "proper" way to do it. I'm not sure how you gathered the bit data together, but can you make the vector length 32 bits and just include a few dummy bits? 1 Link to comment Share on other sites More sharing options...
Gabriel Franco Posted September 25 Report Share Posted September 25 Create a 32 bit array tag (Output_Array_EIP) to be used as adapter output and copy origin 30 bit array (Array_Bit_Origin) to this new array of 32. 1 Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 25 Author MVP 2023 Report Share Posted September 25 Thanks @Dave & @Gabriel Franco. That worked. All it wanted was for the vector to be evenly divisible by 8. Link to comment Share on other sites More sharing options...
