Posted
Hello everyone
I am using a V700 for a machine control. Parallel to the local control, I would like to install a remote control in the same network using Remote Operator. With the new security settings, it is apparently not possible to operate the remote operator without a PCOM password. However, as I don't have a keyboard on the remote control, I can't enter the PCOM password every time I start it up. Is there a way to enter the PCOM password once and store it permanently on site?
Thank you for your help!
Posted
I use a small industrial touch-PC with Windows 11. I have the Remote Operator in Autostart so that it is automatically activated after switching on. Unfortunately, I always have to re-enter the PCOM password. But once the step to the new firmware has been taken, there's no going back 😉
  • MVP 2023
Posted
Well...there is...but...   The important bit here is whether the network is connected to the outside world.
cheers, Aus
  • MVP 2023
Posted
32 minutes ago, MarcBickel said:
Unfortunately I can't download the file.
It looks like a problem with the Forum itself. It's likely temporary.
Posted
8 minutes ago, Flex727 said:
Why not?
Because I already have several identical systems in use without Remote Operator and they also have the latest firmware version. I don't want identical systems with different firmware and software versions.
  • MVP 2023
Posted
11 minutes ago, Flex727 said:
Why not?
Excellent reason.
Posted
21 hours ago, Saragani said:
Actually, I've compiled Remote Operator 1.0.100 2 months ago, and I don't know why it wasn't uploaded to our website.
Version 1.0.100 works with local storage for the passwords instead of RAM, so you will not have to re-enter it each time.
Please try it and tell me if it works for you.
Remote Operator Version 1.0.100.zip
The download has now worked 🙂
Unfortunately, I get the following error message when starting a remote session:
Posted
OK, try replacing the Remote Operator.exe with this file:
Remote Operator.exe
The old one was compiled as Any CPU, and as far as I understand, the OLEDB error happens due to accessing OLEDB on 64 Bit. The version I gave you now is compiled as 32 bit, so it should work.
Posted
6 hours ago, Punt Systems said:
Hi Marc,
If you use Remote Operator version V1.2.85.3, you can save the password, and can go from boot to a (full screen) PLC in one move, without any click.
Best regards
George
Hi George
Thanks for the hint. Where can I get this version of the Remote Operator? I found something about it in the download section of the forum. Unfortunately, I always get an error message when I try to download it.
  • MVP 2023
Posted
DOWNLOAD ISSUE FIXED.
THERE IS CURRENTLY AN ISSUE WITH DOWNLOADS NOT WORKING ON THE FORUM.
Volunteer mods do not have sufficient access to fix the problem.  Hopefully will be cured soon.
Register a new account
Sign in
Important Information
