Posted
Dear all,
I have the following issue/question. My company designs and builds water and waste water treatment plants and Unistream is our standard. Due to scope of technology, I always have  a lot of pumps and valves controlled by a PLC. Therefore I have defined structures for these elements and there is a rule that each element has two basic states
1. Manual where the user can simply start or open pump or valve without any restrictions
2. Automatic where the element works according some conditions
I always implement a button called "AUT" which puts all the elements to an automatic state and also a "STOP" button which puts all the elements to manual states and switch off (or close)
Thus for example, the pump structure always contains in C# notation something like that
struct SPump
    bool InAut;
    bool ShouldRun;
The AUT bottons sets InAut to true; the STOP buttons sets InAut to false and also ShouldRun to false.
I always draw in ladder for each element something like InAut-(S)- or InAut-(R)-ShouldRun-(R)- respectivelly for STOP button.
The question is how to achieve the same effect using For Each loop. Any Idea?
Thanks Jan
Posted
Create a list of your pumps, create a ForEach function that accepts a list of Pumps.
Call the ForEach function with your list.
The ForEach function has a local tag called CurrentItem. Do your logic on the CurrentItem
  • 2 weeks later...
Posted
Bump.
Is there a size limit on how big the struct tag called by ForEach can be?
For example, I have a ForEach loop which updates a data table containing same structure as the struct in question. I do a simple query: CurrentItem.Index == Data Table Row 1 data (e.g. material code), and when same, it updates the data table row (CurrentItem -> Write to DT Row)..
This function worked kinda erratically. Data table couldn't be updated past row 3 or 4, so I've abandoned the ForEach and replaced it with 30+ rungs with compare functions. So it's solved for now, not just in the elegant way I wanted.
Posted
Quote
The answer is no.
Can you please post your code or show print screens so we would be able to help you better?
Posted
Maybe you need a foreachloop in a foreachloop.
Ther parent foreach with all your structs and the inner foreach with your data table ?
please be more clear about "data table couldn't be updated past row 3 or 4...."
in your foreach with data table as "input", you only work with "current index" row of the data table
Register a new account
Sign in
Important Information
