Posted
Hello,
I have the below within range statement, which appears to evaluate to true, though it definitely isn't. Any ideas what might be causing this? As soon as I started typing this email out, I did realize that the high and low should have an extra 0 and 9 at the ends or each (9 numbers long, should be 10), but still, it should be false I feel.
Subroutine is called in the main routine.
  • MVP 2023
Posted
Don't worry Johnny, I often get this one confused.
It is straightforward and I don't know why I do it, but I think it is the strange way it is shown in the element.  For my brain, I think I want to read A first in the line shown.  The way it's shown if you read it from the A perspective, it makes sense, as going backwards  to B means that A is >= than B.
cheers, Aus
Posted
I caught the fact that Johnny had a number mix-up, easy enough to do...
But, following up on Aus's comment;
I agree that it can be confusing, I think it should read " A<=B<=C ".
With B being the input number, so visually it make more sense, the input number is "in between" your High and Low range, so it's "within range"
Just my 2 cents..
JohnR
Register a new account
Sign in
Important Information
