Rogerio Posted November 24 Report Posted November 24 Hello, good evening. I programmed the PLC V130 and now I'm using V350. I loaded the program and it turns out that the descriptions of the data table write a part of the description. For example, "start sequence" in V130 and in V350 only "start" appears in ACS II String
Cam Posted November 25 Report Posted November 25 Is this occuring when your reading data from a data table? If so can you post the code your using to read the data table for review?
Rogerio Posted November 26 Author Report Posted November 26 On 25/11/2024 at 11:01, Cam said: Isso está ocorrendo quando você lê dados de uma tabela de dados? Se sim, você pode postar o código que está usando para ler a tabela de dados para revisão? Hello good morning, this is only happening on the V350, so everything works on the V130. I can even send you the code but it will be confusing to you because the program is still being developed and I need to organize it better. To help you, I am from Brazil and the language makes it difficult to understand.
