bsautomation Posted September 18, 2010 Report Share Posted September 18, 2010 Can any body help me in getting linear o/p 4-20mA proportional to loadcell i/p Quote Link to comment Share on other sites More sharing options...
Phil Salkie Posted September 20, 2010 Report Share Posted September 20, 2010 In your "HW Configuration" page, you define the hardware you'll be using with your PLC. In those tabs, you'll see entries for the analogue inputs and outputs - assign MI registers for each input and output you'll be using. Your raw loadcell input will now show up in, for instance, MI 400. Now, scale that to match the output range you'll require for your analogue output - the "Linearization" FB will likely be quite helpful there - and place the value in the register you've selected for the analogue output, for example MI 410. Quote Link to comment Share on other sites More sharing options...
