Check out the Help on UniCAN- you can send 32 messages per scan. I'd put seven UniCAN Send blocks in consecutive networks and let 'em fly. I've done this with four and had no problems whatsoever. As good programming practice, use Check Alive blocks beforehand to make sure they're online before you trigger the Send blocks and put some code and screen notifications in to handle an offline condition.
