JZ10-11-T17 counter reset
Im am not sure exactly what you need to do, but lets say that you have a need to say measure the length of something perform an action then reset the counter valvue so that you can repeat the process over and over again (or something like that). This line of thinking should also work for any time you want to reset a counter.
It is just as simple as picking any event, input, counter value, etc and saying that when any of the conditions you care about are true that you direct store a value of zero in the memory location your high speed counter is inputting to, So for example you have a counter going into MI0 and when the counter gets to 2010 you want to reset the counter to zero or if input 0 becomes true you want to reset the counter.
Keith
