dbrew0 Posted March 8, 2012 Report Share Posted March 8, 2012 Hi all, I am using a V570 and have a Binary Image which shows an off/on switch (uni_R_off, and uni_G_on). There is also a text box behind it. I am using VisiLogic v9.3.1 When conditions exist that I don't want the operator to be able to use this switch I want to hide the binary image and have the text behind it visible. I use a hide bit on the binary image. This sort of hides the image, but a blank grey block still sits over the text where the image is. I have checked the transparent background box, but that doesn't make the grey block disappear and allow the text behind to show through. Is there a way to completely hide the binary image? Thanks, Dan Quote Link to comment Share on other sites More sharing options...
Walkerok Posted March 9, 2012 Report Share Posted March 9, 2012 Hi Dan, I do not think that there is a way to make this not happen. I use hide all the time to hide switches or notices but I have never stacked items on top of each other. I do not beleive that the system will allow you to stack items an I am always careful to make certain that I never oveloap items on the screen. If someone else can tell us how to do this (if it is possible) I could use to know also. Keith Quote Link to comment Share on other sites More sharing options...
HigHTech Posted March 14, 2012 Report Share Posted March 14, 2012 What I do: Make a list of images, write your text in the same background color and change your logic to use the list. That works for me, you need to work more but it´s the only way. Quote Link to comment Share on other sites More sharing options...
